跳转到主内容
Corsair rams 4x2 (8G) 1067mhz
Hello guys.
I have purchased and installed my new rams corsair 8g 1667mghz
I would like to know my MacBook Pro rams was 1066mhz but now it is 1067 MHz is that okay or not I see lots of people using this corsair rams but I would like to knowledge myself and learn is it okay if the rams has a higher speed than the actual speed of the machine like 1066 mhz to 1067?
http://qkpic.com/15b0b
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
If your computer is working properly I would not worry about the difference between 1066 and 1067. My main concern would be does Corsair certify this ram for use in an Apple computer? If so no problem but if not it could cause system board problems over time. Ralph
这个答案有帮助吗?
得分 3
1条评论:
agreed +
完成的
添加一条评论
this is the link
http://www.newegg.com/Product/Product.as...
这个答案有帮助吗?
得分 1
5条评论:
Looks good to me. Ralph
完成的
outside of being a bit overpriced, looks good to me +
完成的
That ram is 1066, not 1067...
完成的
Well sorry brother but I am not the one who said 1067! it is written in the website + on the plastic box of the rams.
完成的
Gabe thanks so much for helping me in this post :)
Best 4g and 8g ram memories for MBP?
I am very satisfied with the rams ^^
完成的
添加一条评论
Thanks so much guys
Is there any thing I should do after I install the rams? like resting something pram or something like that?
这个答案有帮助吗?
得分 0
1条评论:
nope
完成的
添加一条评论
Guys anyone know why my machine temperature increased after using my new 8g rams? (with no Vmware ) with VMware it gets worse
the cpu is 80 centigrade and it goes to 70 if there is no lots of apps working.
note: I did not reboot my machine since 6 days because the machine looks quite fast and no need for refreshing memory.
这个答案有帮助吗?
得分 0
添加一条评论
With this speed, it rounds, since technically the ram it running at 1066 and 2/3Mhz (.666666666_ Mhz) some companies/operating systems will round up, and others will round down, the ram is the same speed whether it says it is 1066Mhz, or 1067Mhz.
这个答案有帮助吗?
得分 0
1条评论:
Thanks but can you answer my last question?
The machine gets hot very fast also the cpu above 70
完成的
添加一条评论
添加你的答案
Mohammad Fadin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 3,869
