跳转到主内容
The Dell Inspiron 580 covers the basic computing needs. It may not provide the most advanced version of each feature, but the basics are available and provided for users.
12 个问题 查看全部
Can't get past the dell start up screen
Whenever I turn the computer on it starts up normally. Once it gets to the screen where it offers the options for boot menu and stuff, it goes black after it finishes loading. I may have caused this because I messed with the bios to usb boot chromium, now it won't boot to the hdd. (I reset the bios by taking out the battery for a little while, and it still has the same result) Help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
yben, the Dell Inspiron 580 Service Manual Dell™ Inspiron™ 580 Service Manual says that to reset the current CMOS settings:
Locate the 3-pin CMOS reset jumper on the system board.
Remove the jumper plug from the CMOS reset jumper pins 2 and 3.
Place the jumper plug on the CMOS reset jumper pins 1 and 2 and wait for approximately five seconds.
Remove the jumper plug and replace it on the CMOS reset jumper pins 2 and 3.
So give it a try. Once in the BIOS you should select safe boot options or similar choice and see if that works. If it does not you will have to flash the BIOS. Check on here for the software. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
yben24 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 917
