跳转到主内容
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
130 个问题 查看全部
The tip of the power cord broke inside the power source.
The tip of the power card broke inside the book, I can not get it out, is there a way to do so
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
which power book?
完成的
G-4 Power Book
完成的
添加一条评论
4个答案
已选择的解决方案
It's hard
some have had luck removing the bottom case and working it out of the socket from underneath using pins, needles or small thin electrical tweezers.
If this answer is acceptable please return and mark it.
Good Luck,
N.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
After you open your machine, remove the DC-IN port. The middle bar on the back of the unit can be pulled out slightly. After doing so, most of the time the tip can be dislodged and removed. If you give us exactly which Book you have we can lead you to the specific instructions on how to open your Book.
这个答案有帮助吗?
得分 1
1条评论:
+Ralph
完成的
添加一条评论
Hello
The same thing happened to me.
What I did was, I put a small drop of super glue (gel type) on the broken part of the pin connected to the cord and after 10s I inserted it again in the powerbook. I Let it stay plug for some minutes and then pull it out.
The tip came out halfway and then it was easy to pull it out with a plier
(in my case the outside metal barrel was so damaged that I had it sawed off)
Don't use to much glue and limit the glue just to the inside diameter of the tip or you can end up with a non working full time connected power cord... :-)
Hope this helps.
Paulo M.
这个答案有帮助吗?
得分 0
添加一条评论
<h1><a href='http://www.cnpowercords.com'>power cord</a></h1>
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elizabeth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 2,455
