跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
MacBook won't power on
Hello,
My MacBook (late 2009 Model) won't power on. After reading here, I replaced the battery because it was right about 5 years after I purchased, which is the apparent battery life. Unfortunately, the problem still remains. The replacement battery charged up (light was orange initially and eventually went green) but after pressing (and holding sometimes) the power button there is no reaction (no noise, no fan, nothing). What should I do now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I actually just googled a bit, and maybe one of this already asked questions help, It isnt exactly the same model but it should be the same procedure
Here: My MacBook Pro 13" won't turn on
Bit longer Here: Solutions as to why my MacBook Pro won't power on?
Now my grandma advice apart from those above, if you try any solution above and are ready to trow it trough the window keep calm, drink a coffee and open again, and check the Keyboard connections are proper connecting, I have a powerbook G4 fixed last week ( I know you must be laughing at me xD and you should) the problem was no audion and no usb on the left side I opened and everything was perfectly connected. I than used the Grand ma trick, I basically bought 100% alcohol ok something like 99% and with a cotton bud I cleaned every gold connection that could cause my problem, In your case the Keyboard if I am right so I suppose if you open again give a good good check up clean all the gold pads check everything is well and deep plugged, you have good good chances that It will turn on just like magic. :O ;) \o/
Cheers
这个答案有帮助吗?
得分 2
3条评论:
Thanks! (I saw those, but wasn't sure about the similarities...I'm a neophyte at this...) I already bought a new MacBook for work, but I'd really like to salvage this one if at all possible. There's a lot of photos and music on there that I didn't have backed up (my fault, again, I know, I know...).
I'll give it a go, as I don't have much to lose at this point. Thanks again!
完成的
If is the thata that it count for you more than the laptop itself, its not a problem as loong you didn't format anything in between. you could take the 2.5mm Hard drive and plug it either on another close computer, (Shouldnt work) or buy something like this --> http://www.ebay.com/itm/USB-2-0-to-IDE-S...
Or ---> http://www.ebay.com/itm/2-5-3-5-SATA-IDE...
I do have the first one the USB adapter, and its a powerful cheap lifesaver solution, It basicly mount your hard drive as a external one in any computer that you want. You than would need to unmount the hard drive from your Laptop plug with the Usb adapter or the docking station and connect to your work laptop for example, and than save whatever you want.
Best regards
完成的
Saved my machine! Thank you!!
完成的
添加一条评论
Feel the wide chip that's over the mag-safe connector on the logic board to see if it feels concave and let me know.
这个答案有帮助吗?
得分 1
2条评论:
Mine felt concave and I bought and replaced the logic board but it still won't power on.. my mac has been out of commission for two weeks and I'm starting to twitch like a methedone addict going through withdrawals
完成的
Sarah you might want to start a new question with just your specifics.
完成的
添加一条评论
添加你的答案
buddershelper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,340
