跳转到主内容
加入维修社区 - 创建账户
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
MacBook won't turn on, no sound, no screen and no fans blowing
Dear people,
I charged my MacBook last week on work and the next day it wouldnt turn on. Wen I press the on/off button literally nothing happens..
I've tried multiple chargers, power sockets and even left it in the charger overnight. I've left it off for a couple of nights then tried to charge it but it didn't matter.
Some info:
The battery indicator on the side of the macbook doesn't show any green lights when pressed.
The little green light on the MagSafe charger burns BUT very dim, I almost couldn't see it but I just noticed because it was dark in my room..
I was cut out from power at home because we just moved in so there was no electricity. I didn't know that and plugged the charger in the wall anyway. The macbook was turned of at that moment but it didn't turn on after that.
How can I find out what the faulty part is, could it be the battery or could it be more serious like I short-circuited the logicboard.
Is it safe to remove the battery and check if it works without battery but a plugged in charger?
Please MacGods, save me and give me every suggestion you got.
Many thanks and have a good day
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
The very first thing to do is to drop in a new battery. This should at least give us a better idea of what's going on. Of course, that may be all it needs.
这个答案有帮助吗?
得分 1
3条评论:
I'll get a battery soon, kind of worried that it might not be the answer and that I'll be "wasting" money.
完成的
I Replaced The battery with a working one. Still nothing happens and nothing changed. Any ideas left?
完成的
With no symptoms, there's just not much to go on. If it was on my bench, I'd try a known good mag-safe adapter and see if there were any changes.
完成的
添加一条评论
Hello I had the same problem with a macbook pro 17" unibody, I found this and it worked.
http://forums.macrumors.com/showthread.p...
Good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Danny Riem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 23
总计 6,864
