跳转到主内容
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 个问题 查看全部
Computer shuts off after a few minutes of use
Hi,
My iMac (early 2009, 24") started shutting down after a few minutes of use. It's not a clean shut down. It's an instant cut-off of power.
Using Hardware Monitor, everything looks normal except with the Northbridge...
- The voltage sensor always shows 0 volts.
- The current shows 0 as well.
I've tried resetting NVRAM and SMC, but that hasn't helped.
Does anybody have any advise before I replace the system board?
Thanks,
Jay
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
if you haven't already i would try cleaning the dust out, make sure the fan is still spinning, it sounds like a possible overheating issue
这个答案有帮助吗?
得分 1
1条评论:
Thanks Michael.
Overheating was the first thing I thought of. I tried all you suggested.
I also tried using smcFanControl to increase the fan speeds. I replaced the thermal compound on the Northbridge as it was running a little hot (about 75 degrees C at idle). It now runs about 5 - 10 degrees cooler. Everything else seems to be running cool.
So far, nothing has helped.
完成的
添加一条评论
Best to take the frame off and take a look at the diagnostic lights when it goes down. That will tell us where to look.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Mayer. I did that too. It goes directly from 4 lights to 2. Unfortunately that doesn't help.
完成的
添加一条评论
添加你的答案
Jay Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 294
