跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
looking for parts after water damage
Hi, yes I did it, spilled water on my ps4, lots of it...
After dissasembly and cleaning I got it working again except for reading disc's. I need the optical drive controller PCB and a white flex cable. Does anyone knows a ps4 parts supplier? thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
The first thing to keep in mind is that your optical drive PBC is married to your motherboard. If you go and buy another optical drive off of Ebay you will find an error when you try to play any games because the new board is not the one for your motherboard.
With that in mind it is important to try and clean the one you have. The water damage does not look too severe from the pics you posted. Get some 90% + isopropyl alcohol and some q tips and toothbrush. Get the q tip wet with it and rub a generous amount on and around all of the components that are corroded. Then get them good and wet again and take the toothbrush and brush them. This will hopefully get the board working again.
As far as the cable is concerned you can find them on Ebay. There is a wide one and a skinny one so be sure to get the correct one. If you look on the bottom of your board you will see a 010 or 020, as far as I know the wide cable goes with one of those numbers and the skinny cable goes with the other. Be sure to ask the seller which cable it is and maybe even get the measurement just to be sure.
I hope this helps.
这个答案有帮助吗?
得分 3
3条评论:
thank you for your answer! not the one i wanted to hear :-(
I did not know about the relationship between those 2. sounds like the relationship between iphone 5s and the fingerprint homebutton.
the picture was taken before i cleaned it up. after cleaning and checking with microscope i have seen some bad damage.. i wil have to replace the cable anyway because that one is to corroded. replace it and check again.
完成的
Hopefully it will clean up OK. If not you could solder new components on if you have good soldering skills.
Good luck!
完成的
Hi, I was wondering if you were able to get the optical drive working again? I have the same problem... Thanks!
完成的
添加一条评论
my plastatin r has water spilled on it is it broke need some help pls?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ifixshop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 3,151
