跳转到主内容
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
130 个问题 查看全部
Parts for Volume Button
I am looking for an set of Volume Button for my iPad. My iPad went into Yoghurt and now this both Buttons Volume up/down won't work anymore. Will there be parts for that?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
13个答案
已选择的解决方案
I think the buttons only have to be cleaned.
diesassemble the ipad like shown in this guide (but you can see the volume button in step 3 - so you dont have to go all the way with the guide)
clean the button assembly with isopropyl alcohol (>90%) and a soft paintbrush
the needed tools are listed in the guide
good luck
这个答案有帮助吗?
得分 2
4条评论:
Thanks for the Infos. I have Ordered what I need for that yesterday, and I will try.
完成的
I can't find any parts yet. Clean it. +
完成的
Sorry, I was meaning the iPad Display Clip Set, after cleaning.
完成的
+ good answer
完成的
添加一条评论
Did it solve your problem? I had an issue where a drop of water may be in contact and the volume down button no longer works, only volume up.
这个答案有帮助吗?
得分 0
1条评论:
50%. I wa able to open the iPad like it was described here, and the Volume up Button works again, only the Volume down Button was already destroyed. Maybe because I was waiting to long for trying to fix it. The Metal behind the Button was broken. Buy the Tools and clips here and the change to can fix it is very high. Also I hope there will be Volume Parts for exchange that Part in the future. Because a broken clip is a broken clip...
The opening of the iPad is a little hard for the first time, but the glass is very Strong, and after it was not the big deal. Only buy the iPad clips here on ifixit, because you have to replace that.
完成的
添加一条评论
Guys! Did you managed to fix the vol buttons finally?
I've similar problem. My vol(-) button is not working as vol(+). No (sort of) clicking when i'm pressing it. Is it possible to buy whole volume button flex somewhere, or only microswitch should/can be replaced?
Is it possible that iFixit team will post guide how to do it?
I think that button problems are the most common flaws.
这个答案有帮助吗?
得分 0
添加一条评论
No, I opened and cleaned it, but the Button was already defect, like I wrote in my Message above. It's a really pain to have no Volume. Would be nice to have a Part for Replace that Button.
这个答案有帮助吗?
得分 0
1条评论:
the part is on ebay, search for this item number: 260655554854
完成的
添加一条评论
I don't think so, if it's the right one :( It's totaly something else (ipod?)
The rigt one should look more like, google for - ipad volume button flex- pictures.
这个答案有帮助吗?
得分 0
1条评论:
the picture can be the wrong one! - but there are positive feedbacks from people whou bought it - i wrote the seller an email - let's wait and see
完成的
添加一条评论
I hope, that's the real thing. I'll also try to make some more research.
这个答案有帮助吗?
得分 0
添加一条评论
I have no idea if it is the right one ore only the Picture is wrong. I have Ordered one and will try. But the shipping will take a while^^
这个答案有帮助吗?
得分 0
1条评论:
i tried to contact the seller - but he didn't respond. anyway - if you look at his feedback for the part above - he only got positive feedbacks - it should be the right part
完成的
添加一条评论
Well I know that's suck to be kinda rat lab, but if it's the real deal- You're ThaMan! :)
And I'll be next to order!
这个答案有帮助吗?
得分 0
添加一条评论
Hi, any news so far?
这个答案有帮助吗?
得分 0
添加一条评论
I got an Mail today, the have send it now. It was written the send it 3 days after payment. But really the send it 25 days after payment^^ When it is hear I will write again.
这个答案有帮助吗?
得分 0
添加一条评论
This is soooo evil!
这个答案有帮助吗?
得分 0
添加一条评论
that's because they probably didn't have it in stock and ordered it just for you from China.
这个答案有帮助吗?
得分 0
添加一条评论
Didn't arrived yet.
I have a new iPad now, and don't care anymore.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ken ISHIMOTO 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 2,937
