跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Processor replacement
I've used your website to fix 2 iBooks successfully and I am thinking about buying additional ones on ebay for parts and put one together. Can a processor be swapped out or is it included somewhere that can't be replaced? I don't see it as a choice on your repair options. Thanks! And can the light of the monitor screen (if it is dimmer than normal) be replaced as well? Not sure what allows or gives light to the LCD screen. Thanks! Trying to learn more.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The processors are pretty much soldered to the boards, so no, it's not practical. They are not plug-and-play at all. Plus, iBook G3 parts machines are so inexpensive these days, it makes more sense to just get the appropriate board, processor and all. And I don't know where you would get stand-alone processors to use for upgrades, even if the procedure was realistically possible.
Is the backlight dead on the screen that is dim, or is it just not as bright as you'd like? You've tried cranking up the brightness settings, I assume? If the backlight is dead, it could be the screen itself, the inverter cable, or the inverter...typically the inverter cable is the culprit. If it's just not as bright as you'd like, it's probably the screen itself, since they tend to vary a little.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fansfam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,608
