跳转到主内容
为众多三星安卓智能手机编撰的修理指南和拆解,无论新旧,包括备受欢迎的盖乐世产品线。
13179 个问题 查看全部
Is the Samsung Galaxy S3 Neo digitizer identical to samsung i9300?
The digitizer samsung i9301 samsung i9300 is equal to?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
9个答案
已选择的解决方案
No, there are different frame. back cover will not close total.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Yes they are the Same and will interchange
这个答案有帮助吗?
得分 2
添加一条评论
Lcd with touch and frame samsung i9301 same with i9003i(galaxy s3 duos). It's checked in service center yesterday.
这个答案有帮助吗?
得分 1
添加一条评论
I know the lcd frame of i9300 is different from i9305, but not sure i9300 and i9301,
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I know the frames are little bit different between i9300 / i9301, but the display should be the same. I have broken i9301l (Galaxy Neo), but I think when I use following display replacement with the old frame , it should be fine. Can you confirm please?
Thank you very much
这个答案有帮助吗?
得分 0
2条评论:
Please find confirm of pin of lcd/touch connector on this screen, it may be different http://ipic.su/img/img7/fs/kiss_76kb.144...
sorry for my english
完成的
hi xromed,
thanks for comment, but S3 even S3 Neo has a different LCD connector. I don't think your photo is from S3, and if so, its not a connector for LCD. Here you can see the LCD connector, which should be the same on S3 even S3 Neo
完成的
添加一条评论
Si se compri un lcd con screen senza il frame non avrai problemi. Non ho mai provato effettivamente ma per esperienza ti dico che per la parte lcd e frame secondo me sono uguali .
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
yes, I can confirm its the same. I already bought LCD for S3 without frame and its fitting well on S3 Neo - connector is the same. The only think I was missing was a sticker between the frame and LCD (the old one was damaged and I didn't wont to use only slim tape for whole area), so I order one from Ali.
这个答案有帮助吗?
得分 0
3条评论:
hey Halamik
so you put on the sticker and you test it and everything works fine...?
完成的
hi. yes, i just needed to buy the sticker andeverything was fine. the only difference, between S3 and S3 Neo cases is the frame, display is the same.
完成的
thank you for your answer halamik
i asked 6 sellers on Ebay and only 1 the most known & and with the most sales said "yes it is compatible" all the others said no. So i am gonna try it and i am gonna confirm it to...
The only thing it is bugging me is the cheap replicas which you can find on ebay.
Edit: I just notice that you linked before to the seller that said to me "it is compatible"
http://www.ebay.com/itm/Replacement-LCD-...
完成的
添加一条评论
Guys, I tried installing a lcd+case from a neo to a regular s3. It boots something and it shows "galaxy s3" regularly (maybe with a slight flikering). Then once it showed cyanogen mod opening for a second, and then it's all black. The mobile seems working but with no screen functionality. I'm trying and reinstall my recovery from the beginning, my os and then maybe a driver for the new screen?
Does it sounds sensible to me, but is it?
Please anybody have any suggestion?
这个答案有帮助吗?
得分 0
1条评论:
How can you access to change the OS or display driver?? if you don't see anything on display?
完成的
添加一条评论
Hi Giulio, if you said that in the recovery, display is working well, then it should be a problem with your ROM, not with the display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fabio Colombo 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 19
总计 12,651
