跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
204 个问题 查看全部
"Unable to write to the last block of the device"
Hi,
I think i did everything right but now i cannot initialize the SSD not formatted and I receive a "Unable to write to the last block of the device" error when i try to create a new partition.
Screenshots / Pictures :
https://www.dropbox.com/sh/12fcg738jzuxr...
Any idea here ?
Best
Alex
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
已选择的解决方案
Alex - Do you have a universal adapter cable or external case to put the SSD into? See if it can be for formatted externally. If you can, the drives SATA cable is bad.
这个答案有帮助吗?
得分 5
添加一条评论
If it were a normal hard drive I would use the "write zeros", format option to map out any bad blocks. It might work for the SSD.
这个答案有帮助吗?
得分 2
1条评论:
no, the option is greyed in the disk utility ...
完成的
添加一条评论
This problem has nothing to do with the drive itself but is almost always caused by a bad connector between the board and hard drive. A large proportion ,around 10%, of macbooks that come into my lab for disk replacement have a perfectly good drive but a bad cable the problem seems to be most prevalent in the 2010 macbook pro
这个答案有帮助吗?
得分 2
4条评论:
Dani, Agreed, most of the time its the SATA cable. I'm sure Alex has since fixed his system given the age of the original posting. How about focusing on the newer ones.
完成的
Hi All,
I haven't found the solution yet as i have too much work and don't take the time for it to be honest.
I'll retry with your proposals. Thanx a lot for this feedbacks.
All the best
Alex
完成的
bro I have a 2010 MacBook Pro with external hard drive it used to work and work flawlessly but after the wire stretched it stoped working I will try to replace the wire and check again and inform you about what happened I usually think the problem is in the connection nothing to do with the disk itself so replace the wire and bro try again
完成的
changing the cable should take care of it
完成的
添加一条评论
Same problem …. bought two 2TB external hard drives from China ….. one seemed to work when I copied data to it. But would not take the 8.57gb I was sending [ MS-DOS [FAT] ] has a limit of 4gb. Then my MAC would simply not recognise the external drive. I tried all the recommended fixes in Disc Utility on both my rather large Macs [in my recording studio]. One is brand new iMac.
Neither of the two discs are seen by either Mac … I shall turn the problem over to my ‘man’ on Monday [now Saturday] … but, as with most folk, I won’t give in … wasting hours on this problem. Can’t find the answer!
这个答案有帮助吗?
得分 1
2条评论:
This appears to be a Tesla specific problem that is affecting users of Tesla's Sentry mode that records video footage to the USB. Once the USB fills up it appears to corrupt the drive with no obvious solution.
完成的
try partitioning the drives in mac os format (HFS) but you may find that the drives are not really 2TB if they are noname brands
完成的
添加一条评论
maybe you guys are trying too hard reading between the lines and the stupid drive has just bunked ittself over time. that has an odd if one was to calculate it, amongst the other possibles here: hardware main/ hardware aux, internal interface/external connector and even direct to usb!. even solid state has failed for no reason and they are supposed to be impervious to mag/shock without moving parts. go figure
这个答案有帮助吗?
得分 1
添加一条评论
I have this problem with a new USB memory stick. It was filled up to 124 GB by my Tesla Sentry mode but now I cannot erase the data to reuse the stick. Every erase option throws up the “Unable to write to the last block of the device” message.
Any clues?
这个答案有帮助吗?
得分 0
1条评论:
You probably have a problem with the hardware of either the stick or your computer. Try formatting it on another PC and if it doesn't help its time to RTM (return to manufacturer) if it does work on the other computer (most unlikely then you have a problem with your USB port which you can ignore unless you use it often
完成的
添加一条评论
添加你的答案
Alexandre Stevens 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 44
总计 83,415
