跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
How Do I Make My Battery Work?
I dropped my phone down the stairs and the back came off. My phone still worked but I figured it needed a battery change- because we had already ordered a new battery since it had gotten wet a few times before. That battery did not end up fitting so I ordered a new one. My phone is an A1349 CDMA and I ordered a battery that said it was compatible with the A1349 but when I put it in and plugged it into my charger it didn't recognize the battery was there. The phone turned on but there was no service and no wifi- it was only turning on because the charger was plugged into it. I can tell because the phone does this with or without the battery as well as saying 100% and the battery should not be charged very much. The battery fits perfectly. The charger seems to work, considering the phone turns on. I can't go back to the old battery- it is past mutilation. I am wondering if the new battery is not working because the screw isn't in? Does it require the screw for it to work? Or is it because I accidentally broke something or messed something up inside?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Faulty battery or maybe because u stated it got wet a few times also
这个答案有帮助吗?
得分 0
2条评论:
No, the first battery got wet. That's why I replaced it.
完成的
I'd like to know why the NEW battery isn't working.
完成的
添加一条评论
添加你的答案
Alley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 95
