跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
replacement charge connector, why is it different ie no components on
i have just brought from ebay, a replacement charge connector for iphone 4, but noticed that there are no components on the bottom, just lots of glue where as there are on the original, where the components should be, why is this or have i been ripped off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Neil, we can not see what you see. Post an image with your question. Use this guide 在已经存在的问题里加入图片 to help you with that.
完成的
添加一条评论
1个答案
最有帮助的答案
The part you need is iPhone charging port assembly. It has charging port, flex cable, lower mic and connector of the home button flex cable, all a large single part. It looks like this: [关联产品丢失或禁用: IF182-009]
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Neil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 52
