跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Help identifying small internal part
After being thrown in a pool with my 2 month old 32gb 5S, I completely disassembled to dry/clean it. :( It is currently drying in a sealed container of dessicant. However, while disassembling, at one point I picked up and turned over the back half, and this little triangular(ish) metal piece fell out. I have checked countless disassembly and reassembly guides, pictures, and videos, and I cannot spot it anywhere. Can someone please help me???
http://i.imgur.com/oJgxrjs.jpg
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
https://youtu.be/nqVyrhuvF2Y pay attention around 5:50 sec to 6:00 min into the video. I was looking for an answer for a long time. Now you can "see" the answer
完成的
添加一条评论
3个答案
已选择的解决方案
This is the washer under the screw hole on the top end of the logic board
这个答案有帮助吗?
得分 3
3条评论:
I just opened up an Iphone 5 I have, and yeah, there it is. :)
What is this parts function Tom? I know from somewhere that it's an important piece.. Does it help the wifi in some way?
完成的
Which phone did you open? iPhone 5 or 5s?
完成的
Thanks!
完成的
添加一条评论
It's a spacer, It goes under the very top screw hole of the main board, and aligns up against edge of the top housing, with the longest edge of the spacer near the power button. In the tear down guide refer to step 23 or 27 of the comments, I posted more info there.
这个答案有帮助吗?
得分 2
1条评论:
Hi Paul,
Can u pl give the full name of the Teardown guide u mentioned, or the link.
Amer.
完成的
添加一条评论
Step 31!!! There are three small pictures, click each one and enlarge! I had NO idea where this thing went!
iPhone 5s 逻辑主板更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zaitsev77 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 4,947
