iMac keyboard not working
my iMac keyboard is not paring with my iMac can't login
Well let's start with the basics:
1) Is the keyboard powered on?
You can hold the power button on the side of the keyboard and you should see a green LED appear in the top right corner.
2) Does your bluetooth mouse still work?
This can be important in knowing if the iMac's bluetooth card is working properly.
Hope this helps!
这个答案有帮助吗?
I am having a similar issue. I changed the batteries and now the keyboard won't pair. I can't use the keyboard to log in and fix the issue of pairing - vicious cycle here. If the keyboard worked and I could log in, then I could fix the pairing issue. Haha. HELP!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,335
1条评论
First put in new batteries.
由 mayer 完成的
