跳转到主内容
Released in 2013 as a budget smartphone in three models/variants, the Idol features a 4.7-inch IPS LCD panel, 1 GHz dual-core processor, and an 8 MP camera. Includes models 6030A or OT-6030A, 6030X or OT-6030X, and 6030Dual-sim or 6030N.
35 个问题 查看全部
cracked touch screen,unresponsive to touch, display without damage
Hi,
my mobile phone fall down and unfortunately my touch screen is cracked. Partially its unresponsive to touch, but LCD is totally OK.
I contacted authorised service centre and they told me, that its only possible to change the whole screen with LCD, not just digitizer (because of adhesive between). Of course, its quite expensive... Thats why I ask for advice. I found on ebay just Digitizer for my phone, but I am not sure, if I will be able to replace it...
Do you have some manual or good advice?
Thanks a lot.
Martina
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
22条评论
My iPhone 5 got replaced screen the other day and not its mysteriously cracking and not the is a line crack in the middle of the screen and it is stopping the bottom of the screen working. i replaced it because it was badly cracked but not problems still worked but now a tiny crack is stopping it from working I really don't get it and i cant afford another £50 to get it replaced again.
完成的
This is what happened to my iphone 5! It was badly cracked, I got it replaced nearly last week, it was working ok, but honestly really slow, and freezing constantly, but it was still working. Today, I noticed a long crack line down the screen, that I have never noticed before... all of a sudden, it wont respond at all, literally at all! I can't pay $150 again.. this is the 3rd time I've gotten it fixed by the same guy, and they charged me $150 each time.. now it's not working?! over 1 crack! I don't know what to do.
完成的
Hi. I dropped my iPhone 5c last night. When I dropped it, the screen was totally cracked. And the screen was also glitching. After a while. A red light appeared by the earpiece when it wasn't even near water. And now the screen won't turn on. Only a black light. What is wrong and what can I do to fix it
完成的
Well my advice it and do not do it yourself. Go to your service center and get it replaced. In future use a good quality tempered glass screen protector having 9H hardness rating for protection. You may consult this http://www.akshatblog.com/use-glass-scre...
完成的
Our Lenovo S8-50LC tablet had been dropped on the concrete-floor and its touchscreen was cracked. Although the LCD is unbroken, the display seems non-responsive to touch. Several commerce site is selling just the touchscreen for my tablet model. Can anybody tell if just the touchscreen is repairable without changing the LCD for the particular tablet model (Lenovo S8-50LC)?
完成的
显示更多的17条评论
添加一条评论
8个答案
已选择的解决方案
cambiar el lcd(change the LCD)
这个答案有帮助吗?
得分 3
添加一条评论
Martina,
It sounds like you probably won't be able to replace just the digitizer. Many new smartphones feature screens where the LCD panel is fused to the digitizer (Like yours). This makes the phone thinner, but harder and more expensive to repair. If you want to fix your screen, you're unfortunately going to have to replace the whole display assembly (LCD&digitizer).
这个答案有帮助吗?
得分 2
添加一条评论
Ciao! Or, as me, you have to buy a molibdenum wire to separate it heating with a heat gun and a tube of loca glue. It's hard to do.
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
للأسف تحتاج الى تغير الشاشة بأكملها
Google Translation
"Unfortunately you need to change the entire screen"
这个答案有帮助吗?
得分 1
3条评论:
@lpfaff1 @pccheese Gentlemen this is a valid answer. Please reverse your request in moderation.
完成的
Thanks OT, redid translation differently today and your correct!
完成的
My moto 1 cellphone broke totally so can I get back my all the data like pictures ,music n app... Apart from all,, from backup I got my pitures some of.. So can i get all
完成的
添加一条评论
It is possible but very hard to replace both in the first place. But it is almost impossible if your not super good to replace just one. I did two screen and LCD repairs and lost screws and stuff single inside.
这个答案有帮助吗?
得分 0
添加一条评论
The problem is that the screen has cracks, yet you cannot see them due to the depth of the crack. Therefore if the crack(s) disturb the digitizer and its components the system will not be able to recognize any contact with you or a stylus. You would have to replace the LCD Touch Screen and Digitizer. This is not to hard to do and you'll save more money as you can purchase the new touch screen and digitizer on ebay and required tools on iFixit...
Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
Does not let me tap or touch the middle screen an i really need help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martina 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 88
总计 239,384
