跳转到主内容
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 个问题 查看全部
What should I do with the motherboard in my Toshiba Satellite L510?
i try looking tutorial in internet but i stuck on this https://pbs.twimg.com/media/BtOWKcbCAAA9... , can i stick the new part of nec tokin 0e907 now? or i should clean more? i'm so newbie about electronic component
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
kelvin desman, zoom out and you need to give us the whole board picture as well. It will always come in handy to see where the part is located in relation to the board. Is your question how to fix it, what to fix? What have you done so far? the more detail you can give, the greater the likelihood of getting a valid answer.
完成的
we need more information to help you, maybe a alink to the guide your following or even what your doing
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
This capacitors often make a problems. This is 900uf 2.5v capacitor. You can found the same or use several smaller SMD tanatlum capacitors (together they must have the same or a larger value).
Regards.
P.S.
http://www.ebay.co.uk/itm/NEC-TOKIN-0E90...
这个答案有帮助吗?
得分 1
1条评论:
can u tell me how to place it?
完成的
添加一条评论
添加你的答案
kelvin desman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 397
