跳转到主内容
Metal disc on hard drive
I just replaced my stock 160GB 5400rpm hard drive with a 500GB 7200rpm drive using iFixit's guide. I noticed after the fact that there's a metal disc stuck to the hard drive that maybe should be transferred to the new drive as well. Has anyone else noticed this? Any idea what it's for? Since the new drive has a higher rpm I'm concerned I might need it for heat dissipation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Please add a picture.
完成的
Oops, I meant to. It's here:
http://s1.guide-images.ifixit.com/igi/Ml...
完成的
添加一条评论
1个答案
最有帮助的答案
Assuming the metal disk you are talking about is the one pictured in this photo:
MacBook Pro 15" Core 2 Duo型号A1211 硬盘更换
No, the disk stays on the drive.
Make sure your new drive is secure (not loose).
Use software tools to watch your HD and processor temps. Any increase in one can drive an increase in the other.
Temperature Monitor.
http://www.versiontracker.com/dyn/morein...
这个答案有帮助吗?
得分 1
6条评论:
ok +
完成的
Thanks - any idea what the disk is for?
完成的
Maybe to transfer heat away from the hub of the drive to the rest of your machine? ______________ I would _guess_ that it may be specific to that drive family. __________ Ask the TV "Good Question" guy.
完成的
About that picture - http://s1.guide-images.ifixit.com/igi/Ml.... ________ Did you take that picture?___________ In that picture the gray circle looks like cloth rather than metal. There is very sometimes a filter, made of some kind of synthetic cloth-like fiber on some hard drives, and some companies put it on or near the hub of the drive. Disk drives are not air tight or pressurized, like canning jars and airplanes, some small amount of air goes out and in as they heat up and cool off. There is no way I know of to make such a filter out of aluminum or any other metal that is not super expensive (they are called micro sieves - and they can do amazing things, whoops, off topic), but if you could, that would be great, and it would look just like the disk on your HD.
完成的
I'm guessing that it might be to transfer heat, or distribute any force that might be applied to the drive spindle, which is why I was concerned that it should have been transferred. So far my iStat widget is reporting the hard drive at running between 42 and 48 degrees Celsius. It's among the lowest of the temperatures reported, so hopefully that's fine!
The picture is iFixit's own photo (see domain name); the disc is definitely metal and between .5 and 1mm thick.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Aylwin Lo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,140
