跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
How do I permanently delete files from storage?
It says my memory is getting full. I have deleted a lot of pictures off my phone but when I sync's up to my computer all the pictures are still there. How do I erase stuff from memory that I already deleted?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
3条评论:
Yes its the same problem what i delete after few minutes all reappear again
How do i delete permeability
完成的
I want to delete the whole internal storage because if it is searched in the PC it all comes.
完成的
im needing to delete all the up loading ive put in storage. my phone is Galaxy S6
完成的
添加一条评论
5个答案
Open My Files and go through all the files, delete the ones you don't want
这个答案有帮助吗?
得分 0
3条评论:
How do I open "My Files" - I do not have this on my display.
完成的
I've tried this, and the photos are still in my gallery.
完成的
I need to gallery's footed delete please help me
完成的
添加一条评论
its in the tools icon on your phone
这个答案有帮助吗?
得分 0
添加一条评论
You can directly delete unwanted files from your phone by pressing [delete] button on phone. If you want to delete them permanently without recovery, you can use Samsung data eraser tool.
这个答案有帮助吗?
得分 0
2条评论:
how do I recover pic's that were deleted. My phone said that device storage was full. not sure what I did but all my pics are gone
完成的
You can use pro data recovery tool to get them back if they are not overwirrten. There are lots of such tools online, just search it online.
完成的
添加一条评论
after deleting you should not sync your device right away. maybe the sync software have backed up the data you have before. you should check the back up setting on your sync software maybe get a new back up.
这个答案有帮助吗?
得分 0
添加一条评论
it’s not an answer but a comment to “use file manager and delete from there” This did not work either when I went to gallery it was back. However I just read that after this you should off sync. for a while ??? A real pain it should be easier than this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
midboe6 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 18
总计 46,278
