跳转到主内容
Random kernel panics: ram? Not really
Hi guys, I'm Experiencing random kernel panics with my MacBook Pro 13" Unibody Late 2011.
First with old ram ''I received random kernel panic.
MCA error-reporting registers:
IA32_MC0_STATUS(0x401): 0xb200000000030005 valid
MCA error code: 0x0005
Model specific error code: 0x0003
Other information: 0x00000000
Threshold-based status: Undefined
Status bits:
Processor context corrupt
Error enabled
Uncorrected error
IA32_MC1_STATUS(0x405): 0x0980000000000000 invalid
IA32_MC2_STATUS(0x409): 0x0000000000000000 invalid
IA32_MC3_STATUS(0x40d): 0x0000000000000000 invalid
IA32_MC4_STATUS(0x411): 0x0000000000000000 invalid
IA32_MC5_STATUS(0x415): 0x0020000000000000 invalid
IA32_MC6_STATUS(0x419): 0x0020000000000000 invalid ''.
I thought it was a RAM issue so I changed the slot but same problem.
Then I changed my corsair 4 GB stick (CMSA4GX3M1A1333C9) with another 4 GB corsair. Panic still present but less frequent with a different kernel panic.
Then I switched to 2x2GB Sticks but same problem.
I then changed my hard disk to a new SSD: same problem.
I then cleaned PRAM and SMc: same kernel panic.
I really don't know what to do next.
The basic setup I put for testing is: Chrome opened with youtube, Safari opened with Youtube, xcode and eclipse opened.
In 2 hours the system will kernel panic.
Anyone has a new idea to test? Could it be a logic board problem? Maybe I'm so unlucky that I tried 3 different ram sticks and all of them are slightly incompatible to cause this random kernel panic?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Guys, I found a workaround that fixed the problem for me.
I deleted the 2 kexts from /System/Library/Extensions/AppleCPUIntelPowerManagement* and from that moment on, never had a single kernel panic.
Not elegant but it worked for me!
完成的
添加一条评论
1个答案
已选择的解决方案
Experience, to me, indicates a bad hard drive/IR cable that may or may not have corrupted your hard drive. If you don't have an external back up drive I would get one. Back up your user data ASAP. Try starting up in Safe Mode by holding down the Shift key on start up. If you have another Mac available try repairing the hard drive in Target Mode.
After you have your user data backed up, erase the drive using the "write zeros" option in Target Mode. Start up with a black drive and an internet connection to see if you can download and install a new system. But after trying all this and failing, replace the HD cable with a new one (no used parts here) and hope it hasn't destroyed your hard drive.
这个答案有帮助吗?
得分 1
7条评论:
Hi mayer, thank you. I did another test: I removed the main HD (so that no one would use the hd cable) and booted from an usb device (my old mac's hd); unfortunately I'm still getting kernel panics also running from a usb hd (so I think the problem is not in the HD cable). I'm in a deadlock!
完成的
A little extract from the kernel panic:
Processor 2: IA32_MCG_STATUS: 0x0000000000000005
Processor 3: IA32_MCG_STATUS: 0x0000000000000005
panic(cpu 0 caller 0xffffff800fcdcad9): "Machine Check at 0xffffff80100aff89, registers:\n" "CR0: 0x000000008001003b, CR2: 0x0000000000000000\n" "RFL: 0x0000000000000246, RIP: 0xffffff80100aff89, CS: 0x0000000000000008, SS: 0x0000000000000010\n" "Error code: 0x0000000000000000\n"@/SourceCache/xnu/xnu-2422.110.17/osfmk/i386/trap_native.c:168
BSD process name corresponding to current thread: kernel_task
Mac OS version:
13E28
System uptime in nanoseconds: 245375755308
last loaded kext at 67532334983: com.apple.driver.AudioAUUC 1.60 (addr 0xffffff7f911b7000, size 32768)
完成的
What systems were on the external system sources? Your machine requires 10.7.2 or greater.
完成的
Both the hard disks are on 10.9.4. I'm running with temperatures between 70° C - 80°C. Can overheating produce such random kernel panics?
完成的
Just an update: I changed my old ram with a new kit from crucial (it has a utility to check your precise ram model needed) but same kernel panic:
It seems as if Kernel com.apple.driver.AppleIntelCPUPowerManagement(217.92.1) is causing the kernel panic.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
snapshot 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 2,108
