跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
No Backlight After Small Spill
Small spill, shortly after, backlight died for good. Apple says it needs a new logic board. Inverter board sounds more likely to me, but I can't even find reference to one in this machine. Is it built into the log board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Based on this, I'd say the inverter board is the most logical place to start.
Does anyone know where I can find a guide/service manual for disassembling the display module once it's off the computer?
完成的
添加一条评论
3个答案
最有帮助的答案
It is built into the display.
Unfortunately, a liquid spill is most likely to damage the logic board. One way to check is to remove the upper case and look for corrosion on the board, especially near the keyboard and speaker area.
这个答案有帮助吗?
得分 1
2条评论:
This would show whether it was the cause, but if the only symptom is a dead backlight, you'd think more would be damaged, no?
完成的
most likely the L board, i agree
完成的
添加一条评论
There definitely isn't a board just for the inverter but you could try replacing the inverter cable itself.
After a liquid spill, it would be natural of Apple to assume the logic board but if the backlight is the only problem, that seems unlikely at best.
I would try replacing the inverter cable, followed by the display. Only then would I try the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
Take a look at the post below, which has some more potentially useful info.
no display backlight
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
l008com 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 3,441
