跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Why does my phone have color lines across the screen?
I dropped my phone about a week ago and it landed on the back side. Now my screen has lines of color going through it, but no picture. The rest of the phone seems to work properly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 86
36条评论
will it work the same if you have a iphone 4s
完成的
my screen had already been cracked prior to me dropping it i removed the back and pushed down on the area that is connected to the turned off and then back on n still the same thing
完成的
im just trying to get my picture to show back up on my phone not trying to replace the screen
完成的
Okay, so what model iPhone are we talking about.
完成的
Is this an iPhone 5c we are talking about? I only ask because that is the model that you linked.
完成的
显示更多的31条评论
添加一条评论
12个答案
已选择的解决方案
You may need a new screen, Get one from ifixit.
iPhone 5c LCD and Digitizer
Heres the IFixit video.
http://www.youtube.com/watch?v=IA3SIqXv6...
iPhone 5c LCD and Digitizer图片
产品
$39.99
这个答案有帮助吗?
得分 7
4条评论:
this was not helpful I have ab android
完成的
@cassyward28 it isn't helpful to you since you are not in the right device. If you need help with your phone you need to ask your own question and identify your device properly. Use this link https://www.ifixit.com/Answers/Ask to ask your own question.
完成的
I have lines on my phone and I can't get them off what is the problem with it please help me thank you 73 is all I don't know what happened
完成的
I have lines on my phone and I can't get them off what is the problem with it please help me thank you 73 is all I don't know what happened I paid money for the screen and I'm supposed to get it for free to fix it
完成的
添加一条评论
You need a new screen the lcd is damaged
这个答案有帮助吗?
得分 6
2条评论:
I have an iphone 4s and the left side of my screen has a bunch of different colored lines but i can still touch everything on that side, i dropped it face down and it was messed up how should i fix it?
完成的
I have the exact same thing
完成的
添加一条评论
I'm having the same type of problem the right side of my screen is just purple lines and some apps are inverted and the top of the screen is glitchy and the right corner is black with tons of little dots I dropped it like 2 feet off a coffee table like TF I dropped it down many times but this time a coffee table ugh I want this fixed cause I can't make out have the $@$* on my screen cause it's like all inverted it's like looking at a computer screen at it upside down !
这个答案有帮助吗?
得分 2
添加一条评论
my phone will not stay on I put the charger in, its cuts on with different color lines on the screen and once I take it out phone cuts off... sometimes it blanks on and off what is the problem? iPhone 5s
这个答案有帮助吗?
得分 1
添加一条评论
I have an android LG GpadX 10.1" and same thing, I dropped it like 100 times on the screen, side, and back. We're to I get a new screen?
这个答案有帮助吗?
得分 0
添加一条评论
My iPod touch just did this and I freaked out but read some of you guys answers and was like ok let's make it happen
这个答案有帮助吗?
得分 0
添加一条评论
put it in the toilet
这个答案有帮助吗?
得分 0
添加一条评论
I also have the same tyoe of problem. Few months ago i droped my phone and then my screen cracked up i was using it anyway. Few weeks ago i got my screen changed but the same thing is happening to my screen again. While using the phone suddenly coloured line appeared on the screen and then it goes blacked out. When press the upper corner of the phone it gets started again but its not a permanent solution. What do i do now.. (Btw sorry for my bad english
这个答案有帮助吗?
得分 0
添加一条评论
Yesterday I had triped and dropped my phone and now there is lines all over my phone but I can still use my phone but it is so hard to see anything and I am crying because of this please help me cuz my mom don't know that there is colored lines on it
这个答案有帮助吗?
得分 0
添加一条评论
Mines doing the same i dropped it but it didn’t crack or anything and it’s working fine but there’s just these weird horizontal colourful lines that are there
iPhone 6s
这个答案有帮助吗?
得分 0
1条评论:
Now it’s being all glitchy
完成的
添加一条评论
Y'all need a new digitizer
这个答案有帮助吗?
得分 -1
1条评论:
Digitizer is touch screen.
LCD is screen display.
完成的
添加一条评论
I have a moto with the same issue
...... just drop it the same way you dropped it before. that will do the trick.if it don't work buy a new screen or get a new phone
这个答案有帮助吗?
得分 -1
3条评论:
i have a question wouldn't that ruin the phone more?
完成的
My brand new iPhone 7 limited edition Red color just did this. I DID ABSOLUTELY NOTHING TO IT!!! I HAVEN'T DROPPED IT ONCE!!!! I'm crying so hard right now.
完成的
I have a iPhone 6s do I need a new screen ?
完成的
添加一条评论
添加你的答案
Qjones 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 32
总计 237,629
