跳转到主内容
Freezes during boot from HDD and DVD
Hello,
my PowerBook G4 1.67 GHz with 2 GB RAM freezed during the boot process after I foreced shoted down by pressed the powerbotten. It always stops at the white screen with the Apple logo and the spinner. The same thing happened while I trying to boot from the Install Disc. The Hardware Test also can´t work.
When I connet it to a mac mini under firewire connection. HD can be detected but hard to read.
I need to replace HD first?? or some serius problem happen?
Does anyone have useful clues?
Best regards
jyer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like a failing hard drive if it's hard to access in target mode. From target mode, back up your user data. Run Disk Utilities and if you can't repair it, reformat and reinstall the system from the Mac Mini if it is not a Intel processor machine. That failing, replace the hard drive. Here's how to do it:PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement
Here's some hard drives that will work for you: http://www.ifixit.com/Mac-Parts/PowerBoo...
这个答案有帮助吗?
得分 2
1条评论:
+ Ralph
完成的
添加一条评论
Try reseating the RAM, and also try to see if you can verify/repair the drive in any way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sheing Jye chen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,210
