跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
Battery life extremely limited; even after battery replacement?
Greetings,
After replacing the lock button on my phone; My battery life has been very short. In example : full charge at 0900 hrs has to recharged before noon. Thought the battery was old and replaced it, helped but is no where near the expected.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It sounds like there is a logic board issue. As the phones get older of course battery life decreases, lithium ions have a two year life however if that is not fixing the problem I would wager to guess that you are having issues with you logic board and there is no way I know of to repair that other than Cyberdoc LLC and I am not sure if they can fix that without you being able to identify which transisitor controls the power drain.
Other than that I would try the usual tricks: turn bluetooth off, close out of apps and turn your brightness down.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
revanantwraith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 74
