跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Boot loop after screen replacement
I have repaired many iphone 4 screens and have not come across this problem. I changed the screen assembly and got the phone back together and working. It seemed fine when I handed it off to the customer. Wifi was good, cellular had signal, digitizer was operating fine. I had no indication of a problem until the next day. The customer brought the phone back and said that it just shut off and only would come on if plugged in. I took a look to find that when plugged in it would boot to the ios6 greeting screen as if it had been reset but it would not move past that screen. Cellular signal was stuck at searching (witch I realize is irrelevant at this point). I disassembled and checked connections and for visible damage and found nothing. I did notice a burnt smell inside the phone but no other evidence of burning (heat,smoke, black areas on board or housing). now that I got it back together it only boots to apple and cuts off before it completes boot process then comes back on. any advise is much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
100% a damaged battery a new 1 will fix it ..
Had this problem before
这个答案有帮助吗?
得分 1
添加一条评论
Battery, charging port flex and the cellular antenna/speaker in closure have been changed with known good parts and no dice. It's down to a mobo problem. Does anyone know what chips to check for power management? We're is the pmu ic?
这个答案有帮助吗?
得分 0
添加一条评论
However, you can try to fix this with recovery mode which is a failsafe that is used to reflash your iPhone with a new OS.
A great tool i ever used to enter and exit recovery mode is ReiBoot developed by Tenorshare. Have a try. Safe freeware and won't lose data with this process.
Good luck!
Kirsty
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 600
