跳转到主内容
15" HP laptop with 2.60 GHz AMD Phenom II Dual-Core Mobile Processor.
11 个问题 查看全部
My fan is malfunctioning, how do I replace it?
My fan usually gets really hot, even when nothing is running on my computer. Also, when my desk gets bumped or knocked, the fan makes a god-awful noise and vibrates a lot until I restart my computer.
Does anyone have any tips in fixing this problem, if not how do I replace my fan?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Chris, download the service manual from here. Page 73 of the manual will tell you exactly how to replace the fan. Make sure that you use new thermal paste and clean your laptops air vents properly. hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
I've found that my laptop really overheats so I bought a Belkin laptop cooler cushion which you connect via a USB port. It has a cushioned side for your lap and hard durable surface for the device. It has an inbuilt cooling fan and really works well. It was around £30 from Amazon.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 1,893
