跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Battery adhesive removal failure
I have tried to use ifixit guide to replace battery in my iPhone 5s.
When I got to steps to remove adhesive tape, unfortunately the tape tabs just went off (just tore off) without removing adhesive from underneath the battery.
These are steps 21-25 here: iPhone 5s 电池更换
How can I still remove the old battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
添加一条评论
4个答案
最有帮助的答案
Heat up the rear of the iPhone were the battery is situated the aluminum part..
Now pry the battery up with a metal pry tool only pry on the volume keys side not on the motherboard side..
Pry in the middle and bottom side of battery as there is flex cables under the battery at the top of it.. The battery will bend as the adesive is really tuff but saying as your changing the Battery this doesn't matter
这个答案有帮助吗?
得分 5
1条评论:
Ir worked! Thank you.
完成的
添加一条评论
when the adhesive strips are broken , you can try using fishing line to remove the adhesive from under the battery - https://www.youtube.com/watch?v=gkCyl7kR...
also this method using steel wire seems even better - https://www.youtube.com/watch?v=W5GzU11q...
这个答案有帮助吗?
得分 2
添加一条评论
Don't heat up adhesive tabs used to hold down batteries of iPhone 5s, 6 Etc. These are command strips from 3m and become brittle when heated. If you break them off gently pry up on battery using plastic pry tool or isesamo. Be extremely careful not to puncture battery. I get the battery up enough to use curved tweezers and grab a hold of that command strip and pull directly away from itself.
这个答案有帮助吗?
得分 0
添加一条评论
I did two battery replacements back to back, and on the second I used the black spudger as a spool, basically: # NOT cutting the tabs in 2
  1. laying the spudger across the frame with the edge over the battery's bottom edge and pulling the tabs over it
  2. Slowly rolling the spudger towards the home button, keeping the angle of tape more or less vertical from the battery's edge.
On side of the tape broke early on because i misunderstood ifixit's directions and was pulling the tape forward at an angle over the home button hardware. I can't say for certain this method would work consistently but I was surprised how well it did- certainly better than pulling and re-gripping separate tabs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrewborodenko 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 148
总计 37,755
