跳转到主内容
The HTC One SV is a sleek 4G LTE capable Android smartphone that combines great sounding Beats Audio™
15 个问题 查看全部
Why does an error message keep popping up?
An error message saying my dialer has stopped working keeps popping up. It gives you an option of send a report or don't send and it pops right back up after you pick one of the options.
I had my carrier factory reset it and it did not help. Please help save my phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
The issue you are seeing is call "force closing".
If your phone is stock, that is not rooted, then chances are a third party app is causing the problem. If it happens after a factory restore, with no third party apps installed, then you just need to clear the cache.
http://forums.androidcentral.com/verizon...
That's a guide on clearing your cache. You will have to redownload your apps but that should fix it.
这个答案有帮助吗?
得分 0
2条评论:
i cant clear my cache in htc one m8 due to marshmallow update
完成的
? Marshmallow has nothing to do with the stock recovery. You absolutely can still clear your cache after the update.
完成的
添加一条评论
Go to settings then go to apps after that go to running apps and uninstall up date on input sense
这个答案有帮助吗?
得分 0
添加一条评论
I am experiencing the same issues with many apps. Email, clock, dialer etc. I am unable to get into settings.
Same error.
What other options are there?
这个答案有帮助吗?
得分 0
添加一条评论
SOFTWARE updating problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicole Hallett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 10,700
