跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
Can I replace the old Airport Card with Atheros AR5BXB112?
I'd like to use AirDrop feature on my old MacBook, but the original Airport Card inside my MacBook doesn't support it. So I am thinking of replacing it with Atheros AR5BXB112, which is used in MacBook Pro 2009 or iMac Mid 2011. Possible?
Add : My MacBook is a Late 2006 model (A1181) with Core 2 Duo 1.83. (not Core Duo)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Won't work those are 802.11 ac cards and your hardware (and likely your OS) wont support them. If you really have to have this feature see if there is a USB wireless dongle that will support AirDrop in the OS you're using. (FWIW I would not recommend trying to run Mavericks or Yosemite on a machine that age).
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
RadioMan28 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 479
