跳转到主内容
Operating System Genuine Windows® 7 Starter Display 10.1" Screen Size Memory 1 GB DDR3 System Memory Storage 250GB Hard Drive Capacity Graphics Intel GMA 3150 Graphics Chip Dimensions 10.4" (W) x 7.4" (D) x 0.97" (H)
3 个问题 查看全部
问题已关闭
Hangs during boot up and produce clicking sound
My netbook hangs during boot up (upon turning the power on) and then it produces a clikcing sound. A technical friend of mine said it may have something to do with its hard drive. My question is, given the worst-case-scenario that my hard drive is at fault, how can i possibly access my important files on it? Are there ways? Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
The clicking is usually the hard drive search head going back and forth, indicative of a failing hard drive. Back up your data ASAP. If you can, get an external enclosure or a universal adapter to put your old drive in, install a new hard drive. Install some recovery software and see if you can recover your data.
这个答案有帮助吗?
得分 1
添加一条评论
If your display stays dark, it may also be some short-circuit. (However, harddisk is more likely) My son caused short-circuit to my Samsung NB28 by connecting phone charger to laptop LAN-port. After that my computer just clicked and lights went on and off after starting. Taking battery out, didn't help either.
I opened the laptop and connected the two tin-spots on circuit board, which had small text RST (means reset). After that my laptop started to boot again without clicking sound.
这个答案有帮助吗?
得分 0
添加一条评论
Boot problems like those mentioned were traced to a failed cd rom drive. Replacing the drive solved the boot problems. However, simply disconnecting the ROM drive did not.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 286
