跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
How to tell if its power supply or motherboard problem?
I've got an iMac EMC 2308 I'm working on. Once you press the power there is no video, no bong and nothing on the display but I can hear the hard drive spinning and a slight fan noise. How can I tell if its a bad power supply or motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Did you find out which part was broke? My EMC 2308 is doing the same thing and so far no post i've found has helped much other than by saying it is either the logic board or the power supply.
完成的
same issue here, 3 out of the 4 LEDs on the logic board light up and the fans start spinning up as usual but there isn't any display or sound, from what i know, if there are only 3, the MOBO and GPU have a connection established, but a video output isn't being displayed
完成的
@Austin Null this is where the startup sequence becomes important:
LED #1 + LED #2 + LED #3 + LED #4 = Power available, system is powered on, video card
found, and internal LCD found.
If fourth LED is not visible after power on:
• Verify cable connections between LCD panel and logic board
• Inspect LCD display cables for cable damage
• Verify external video functionality, and according to result check the following items:
-If external display works then verify/replace LED backlight board
-If external display works then verify/replace LCD panel
-If external display does not work verify/replace logic board
完成的
添加一条评论
1个答案
已选择的解决方案
There are indicator lights built onto the motherboard that will light up to show you what parts are getting power. Here is a post that should help you.
Where are the diagnostic led's on this model's logic board
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Elias Arismendez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 7
总计 1,000
