跳转到主内容
问题已关闭
Unrecognized battery after HDD and RAM upgrade
After everything done, following your guide. The mac is working properly, except for the battery, that is working, as i can sometimes turn on the mac, with a loud fan noise on battery mode.
With AC power connected it runs good, but there's a cross on the battery indicator, indicating that there no battery.
How can i solve this? what steps should i follow exactly to make my battery recognizable again?
(tried already some solutions, on plugging/unplugging the battery connector with and without AC power plugged in)
Thanks in Advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Is the X red or black?
完成的
Did you solve that? i have exactaly the same problem on the same model
完成的
添加一条评论
1个答案
it's black;
update: the apple hardware test don't recognize any problem. Tried several ways to do de SMC reset, with no results whatsoever (that includes the shift+ctrl+cmf+power several ways; and the unplugging of the battery connector, followed by the "battery reset" (if i can call it so...)
i still think the battery alive, since i've managed to turn on the pc on battery twice (thus the cross was still there, and the fan's were working at full speed)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 196
