跳转到主内容
Guides and support for various television (TV) brands and styles.
9092 个问题 查看全部
Sony Bravia KDF50E-2010 50" LCD HD TV won't power on?
Hello,
I have a Sony Bravia KDF50E-2010 50" LCD HD TV. The red light flashes three times.
What shall I do or what part should I purchase to fix on me own Sony Bravia 50" tv?
When I try to turn it on first green light flashes about 25-30 time. Then I get one red light and the other red is flashing 3 time (continuesly).
Is it worth and possible to fix?
I will be really grateful for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Martin Hawrylo,
If your television is not turning on or showing any signs of life, see the Insignia NS-24ER310NA17 Will Not Turn On problem page for possible causes and solutions.
This error can be caused by a bad bulb, or a bulb that is not tightly secured as well as the the lamp door isn't tight. Check on those things first. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Martin Hawrylo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 461
