跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Key has detached from keyboard
How do I (can I?) replace a broken key on the keyboard? It is the ]} key.
Update
Hi, I can see now how to replace the key! Great, but where can I purchase the replacement part (the plastic hinged frame, which has a missing top hinge pin)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Could you tell us exactly how the key is broken? It will help us help you. Ralph
完成的
Something small like that might best be found on eBay.
完成的
添加一条评论
2个答案
已选择的解决方案
Keys are user replaceable
If the tangs are broken off you'll need a new key. If not one end (side or bottom) sides under a tang on the keyboard, the hinges pop into pins on L & R.
http://www.youtube.com/watch?v=JjRTQIfVT...
Good Luck,
N.
这个答案有帮助吗?
得分 2
2条评论:
Great link if the question asker knows to click on it. Please make your links more obvious. You usually have very good answers but we aren't dealing with power users here. You still get an upvote from me.
完成的
Thanks Machead3!!!
That worked perfectly and was a piece of cake!
I should have guessed there would have been some answers on YouTube.
完成的
添加一条评论
Yes, keys are definitely replaceable. In fact, there are online shops that specialize in such thing. Check out http://www.laptop-keys.com to find laptop key replacement and repair kits.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
billgaskins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,981
