跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
No Boot Unless PRAM Unplugged
I have now tried 2 different logic boards (a Core 2 Duo 1.83 and a 2.0) in a MacBook that I have, and both behave the exact same. They will only boot if I take out the LB, unplug the PRAM battery, wait a few seconds, plug it back in, and then get it all hooked back up. And even then, both of them would only boot once and then never boot again until I repeated the process. I have tried 3 different PRAM batteries with the same results. I am losing my mind trying to find the culprit! When the computer does boot, everything seems to work perfectly, including bluetooth, wireless, charging the battery, etc. Any ideas on what is preventing the boot? By the way, when I say it will not boot, it literally does nothing when I press the power button.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Not sure how this fixed it, but turned out the MacBook just needed a new top case (keyboard + trackpad). For some reason the faulty top case would work for exactly one boot, and not work again. That explains it not booting, since the power button is a part of the top case. I guess the disconnection of the PRAM battery was making it forget enough settings that it would get one boot before failing.
完成的
+ vote for the answer to a real tricky question.
完成的
@brant - Please accept the answer to get this resolved question off of the unresolved list. Thanks!
完成的
添加一条评论
2个答案
已选择的解决方案
OP solved own problem
branttaylor,
这个答案有帮助吗?
得分 0
添加一条评论
When you're confronted to such a problem it's better to disconnect all the logic board connectors (minus magsafe connector), connect headphones to the sound port and trip the power pads on the logic board to boot it. If the logic board always chime each time you trigger the power pads then you plug the disconnected connectors one at the time and trigger the pads until you find the culprit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
branttaylor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 14
总计 2,023
