跳转到主内容
Clothes dryer repair and support guides.
771 个问题 查看全部
Squeaking noise when start up on Maytag Bravos Quiet Series 300 dryer?
The dryer is squeaking when beginning a cycle
After it is warmed up or in use for a few minutes it seems to not be as bad
Is there an easy troubleshooting method?
Could it be a bearing or is it a belt?
Where do I begin?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
最有帮助的答案
I find your photos of a repair on a GE dryer interesting, but this is not the same design as the Maytag (Whirlpool) dryers. The Bravos 300 series are very similar to the Maytag Neptune series.
To replace the two wheels (located inside the rear of the dryer) on which the dryer drum rides - these do wear out depending upon frequency of machine use and size/weight of the loads. The front of the Maytag machine must be removed, then slide the drum out, and use a ratchet with socket to remove the two wheels with their holding bolt. A kit containing all the necessary parts can generally be purchased through an appliance parts center for about $40-50. Be sure to have your model number when ordering/purchasing the parts.
这个答案有帮助吗?
得分 2
添加一条评论
It's probably a worn out drum bearing. Here's a pictorial guide on replacing one: http://marksprojects.wordpress.com/2009/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 16,831
