跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Why is my Galaxy S3 stuck on the samsung logo?
So I put my galaxy s3 on factory restart because it kept freezing on me and now I can't get back on. Why? I don't know. It loads and then it gets stuck on the blue samsung logo, then shuts off and no matter how many times I try, it doesn't load. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
最有帮助的答案
When you do factory reset may damage some files and cause the software problem. You can try to root the phone.
这个答案有帮助吗?
得分 4
1条评论:
i am having the same problem
完成的
添加一条评论
Boot into recovery and wipe data or factory reset
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like you reset the phone from the settings menu, correct? Try this:
Hold Volume UP, and the home key down at the same time. Now, while still holding those two keys, press and hold the power key.
When you see the Samsung logo you can let go of the power and continue to hold the other two keys. You will see a screen with blue text that says "Android Recovery" at the top.
Now use the volume down key to scroll down to "Wipe Data" and then use the power key to select it. On the next screen scroll down to Yes then again select it with the power key. This will hard reset your phone.
When it boots up, allow upto 15 minutes for it to fully boot.
Report back with what happens!
这个答案有帮助吗?
得分 1
1条评论:
Thank you! Just had this problem after doing a factory reset on my old S3 phone and your instructions got it up and running again.
完成的
添加一条评论
If you can't boot into recovery and only download mode and can't recover via Odin your eMMC chip is dead known as sudden death syndrome with the S3, or it just naturally died. Your options here are removing the eMMC chip and using a micro SD as bootable storage (last resort)
try recover via odin etc first
这个答案有帮助吗?
得分 1
添加一条评论
I tried to use your solution, but when I downloaded the odin 3.07 I got a browser hijack spamware and just got done getting rid of it. Now I downloaded Avast to get rid of it it wont let me download it at all due to malware stuff in it. http://spacyroot.com/
这个答案有帮助吗?
得分 1
添加一条评论
You might have to reset the p-ram . In iPhones,this is achieved by disconnecting the battery and then reconnecting it. Hope this helps you out with this problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DJ Kitty 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 33
总计 7,498
