跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4s battery doesn't fit iPhone 4s
I have an iphone 4s logic board and i am trying to test to see if it works, so I bought an iphone 4s battery and the connector doesn't fit. It is OEm and I have tried other peoples battery right out of their phone. Nothing works. The iPhone 4 battery fits but doesn;t power. I know I don't have an iphone 4 because the power button connector and those connectors are on the left side of the board, not the top like the 4. What's going on with my iPhone board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If in doubt, the best to do is to post an image of your phones logic board and connector with your question. Here is how you do that 在已经存在的问题里加入图片
完成的
添加一条评论
3个答案
已选择的解决方案
Lucas Darder, "iPhone 4 battery fits but doesn;t power" is a pretty good indication that you do not have a 4S. The batteries are not compatible and will not interchange. APN 616-0580 is the 4S and 616-0513 is the iPhone 4. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
You have an iPhone 4, CDMA version--aka Verizon version.
You'll notice that your logic board also does not have a SIM card tray.
jessa
这个答案有帮助吗?
得分 1
添加一条评论
Can you post a picture of your phone and the battery that you are trying to connect? How many screw holes does the new battery have? 4s batteries have two, regular 4 has one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lucas Darder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 1,846
