跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
RAM - capacity and type
I have an iMac 20" / 2 GHz / 512MB RAM computer. There are 2 slots for memory boards EMC No.: 2105. Only one slot is used = 512RAM. Can I purchase an additional 512RAM board without removing my current 512MB board? Or, do I have to remove the current 512MB and purchase a 1GB ram board? Also, please advise specifically which memory board I should purchase? I'm probably not using the correct lingo. Thank you for your help...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Your 20" iMac which is the the early/mid 2006 iMacs (iMac4,1). The maximum RAM for that is 2 GBs. You can mismatch the RAM sticks (1 512 and a 1 gb card)
The RAM slots support 200 pin PC2-5300 (667MHZ) DDR2 SO-DIMM
这个答案有帮助吗?
得分 2
2条评论:
+ Ralph
完成的
Agreed +
完成的
添加一条评论
This Machine uses standart DDR2 so-dimms. You can add a second memory card of 512 mb or go straight op to 4 gigs of RAM with two 2gig cards.
这个答案有帮助吗?
得分 0
2条评论:
Could you technically use a 1GB or 2GB stick in addition to the 512MB stick? Or does this machine require matched memory?
完成的
I believe the max on this machine is 2GB. http://www.ramdirect.com/macs/iMacMA200L...
完成的
添加一条评论
I know this question is old, but if you have an iMac 2006 EARLY (please note EARLY), there is a custom ROM that you can install that will allow you to max it out at 4GB, but only 3+ will be visible.
READ all the comments in this link before you decide you want to do this. It is not an Apple supported ROM.
http://forum.netkas.org/index.php/topic,...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
richardshelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,682
