跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
709 个问题 查看全部
No Display on in built screen. but has display to external.
The Main in built screen does not give any display what so ever, its completely black. The unit turns on and gives the start up sound. It also can display to a external monitor connected through thunder bolt. I have replaced the screen with no luck and I have also replaced the led driver board with no luck. the logic board shows 4 green lights as well.
any help would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Open it up and check if the LVDS (display data cable) is damaged or loose. Try a known good display data cable. If this fails replace the LCD.
这个答案有帮助吗?
得分 0
1条评论:
I'll give it a shot
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 152
