跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 个问题 查看全部
stuck in emergency mode
stuck saying emergency mode connect to kies .when connected to kies will not down load stock firmware.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
There is a variation for each carrier around the world for the Galaxy S2, and if you provide which carrier it is for and the model number (on the back behind the battery), I can point you to the correct official ROM and ODIN download to attempt to fix this with.
完成的
how would I provide you with the carrier details?
the model number is:RVRB814865E
完成的
That's a serial number, not a model number.
I am looking for something like SPH-D710 or T989UVLE1
完成的
ohh sorry,
model number: GT-I9100
完成的
添加一条评论
3个答案
已选择的解决方案
Let's hope some of this information is helpful:
Causes of stuck in emergency mode:
No service (Can be caused by IMEI missing, generic IMEI, sim card not reading properly (usually the sim card reader physically damaged).
Solution for IMEI missing:
- Rewrite imei on phone, this is needed for generic IMEI (0049xxxxxxxxxxx)too (using tool such as Z3X box)
- Reflash firmware on phone (Using ODIN [Avoid losing data on just flash], Samsung Kies / Smart Switch [Will wipe user data on flash])
Sim card not being read:
- Re-align pins
- Resolder broken off pins
- Replace sim card slot.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Hi,
Try to do a factory / hard reset. Power off the phone and remove the battery for 4-5 sec.
Press and hold together the Home, Volume Up and the Power button. When you see the Samsung logo release only the Power button.
Now from the Android system recovery menu choose "wipe data / factory reset", "Yes -- delete ..." and "reset system now". Use the Volume UP/DOWN keys for navigation in the menu and the Power for OK.
This operation will erase all your data !!!
Regards.
这个答案有帮助吗?
得分 2
1条评论:
I have a same problem but I get firmware recovery main screen -- not the samsung logo.
完成的
添加一条评论
what if I couldn't do that, its giving me a black screen with error in connection icon, or the same screen that's appears when I am in the emergency recovery mode I think.. how can I fix this??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Glenn Pender 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,666
