What does the "Err" error message mean?
My camera's screen reads "Err." What is wrong and how do I fix it?
Assuming that you're seeing "ERR" in the viewfinder display, there are a couple of common problems associated with this message. Check the LCD screen for additional information, such as "Start-up error" or "Auto-exposure error." Often the problem can be resolved by removing all accessories, the memory card, and the battery, then re-inserting them. See the Nikon D5000 troubleshooting page for more details.
这个答案有帮助吗?
hola soy técnico profesional de cámaras reflex nikon canon etc. el problema de tu cámara nikon d5000 es un problema con la unidad de apertura,(problema mecánico generalmente) este problema se presenta mucho en nikon presentando err. verifica si el espejo esta bloqueado,trata de empujarlo hacia arriba y comprueba si es eso el problema, si no, baja la maesilla que controla el diafragma del lente si esta trabado eso es el problema llévala a servicio técnico .aveces esto pasa cuando se golpean.
这个答案有帮助吗?
hola mi nikon es una 5100 y saca foto de cerca y salen clara. tiene un lente de 18-55 pero cuando saco fotos lejos queriendo aprovechar el lente me salen distorsionadas .
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 26
总计 1,483
2条评论
Help us help you. The more complete the description of your problem is (what happened before the message - dropped, wet, other) a full compete description the text or screen shot of any error messages the more assistance we can provide, and, the sooner we can provide it..
At this point all I can say is your camera's logs board is reporting a problem.
由 originalmachead 完成的
Hello I have a problem with my Nikon D5300 it just went off wen I was shooting a video till now it's just bring un error inside the view finder.. I don't know the problem and display is not working since that day
由 keith Nkonde 完成的
