跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
Help! Kickstarter won't budge!
The kickstarter will not budge a bit when I try to kick it over, what should I do?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Is it used often? or has it been left unused?
完成的
I really don't know how long it's been sitting. I think it's an automatic as well so how would I get it in gear?
完成的
添加一条评论
2个答案
已选择的解决方案
the suzuki fa50 is has a built in safety release mechanism on the kickstart gear. The kickstarter will not engage without the rear brake lever depressed.
这个答案有帮助吗?
得分 3
2条评论:
Not that you need to know this Tim, that is correct. I had 1 of these in the early 1980's
完成的
surely that would have been illegal..lol
完成的
添加一条评论
It could be jammed--sometimes if you put it in gear and push it things will free up. Otherwise you must disassemble the mechanism to find and clear the bind. Ralph
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thegaragequeen22 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,632
