跳转到主内容
加入维修社区 - 创建账户
HTC One(代号 M7)是 HTC 2013 年的旗舰智能手机。它采用无缝的一体成型机身设计、双前置扬声器,并配有一块 4.7 英寸 1080p 显示屏。
Phone doesn't read SIM-card
Hello,
I have a HTC One that does recognize when you insert a SIM card, but it is unable to read the SIM-data.
When you insert a card it shows "Preparing Simcard" but doesn't show provider information and has no reception.
Is this a faulty Sim Card reader?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
my htc one no signal no imei why ?
由完成的
添加一条评论
5个答案
已选择的解决方案
Maybe the Antenna is broken, check the connection of the cabels and clips that go to the backcover.
MFG
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Have you tried restoring the phone to defaults ? (don't forget to backup your data before doing this). Some Android users that I know already had this kind of problem and it seemed to be linked to a software problem. You may thy that before starting any repair !
这个答案有帮助吗?
得分 1
添加一条评论
it didn't help. Maybe I should mention that the phone is already opened.
Is there any antenna in the backcover so the phone cant get the provider information and reception?
the sim slot seemed to be ok because every pin in the cable had contact to a sim pin.
这个答案有帮助吗?
得分 0
添加一条评论
I changed the reader and noticed it was ok. The phone reads the phone number from the SIM card but since it has still no reception it can't receive the provider information. Any solution for this?
这个答案有帮助吗?
得分 0
添加一条评论
ok go to settings then go to about phone open to operator & it should tell you who the operator is if is working properly. ihave found they take a while to process the sim signal as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Domsk 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 34
总计 10,872
