跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
Installed 2nd battery but won't charge. Bad internal charger?
The "Possibly Related Questions" box contains existing text I can't erase.
Re iPod 4th Generation:
Charge graphic blinks and indicates a charge in progress but never happens. I've left it charging for several hours; No charge. I'm sure the battery is not defective.
Is there an internal charger part that could be defective? And is it a replaceable part?
Thank you
Crocdog
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Crocdog, try to charge it with a Firewire charger. Check to make sure that your dock connector is clean, no debris, bend or corroded pins. You can also check the battery connector with the iPod plugged in to see if you receive any power from that. It should be around 4.2V-4.6V. Check the dock connector with a multimeter and see what voltages you get. The pinout for the dock connector can be found here. Yes, there are plenty of charging components on the logic board. All of them are SMC and would require a sound knowledge of soldering as well as the right tools. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Re: Crocdog charging the A1099 /20GB Ipod
Thank you O.T.03!
The docking connector answer worked perfect. It charged right up away.
The poor thing is now healthy and holding on to a charge...Saved from the bone yard!
Thanks again...
Crocdog
完成的
Crocdog, you are welcome. Best of luck to you.
完成的
添加一条评论
添加你的答案
Crocdog 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 402
