跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
What is the best tool to use for the standoff screws?
the bloody standoff screws in the iphone 4 are so hard to find a good fitting tool for! What is the best tool that someone has found to handle the standoff screws???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Here you can find different market reports about tools-
https://www.factomarketinsights.com/
完成的
添加一条评论
4个答案
已选择的解决方案
I take a small Phillips and grind it down flat and that allows me to have connections at all 4 slots. I find the flathead slips out a lot and harder to put back in with flathead.
这个答案有帮助吗?
得分 3
1条评论:
Excellent solution. This really works.
完成的
添加一条评论
You can find all the repair tools on ifixit. You can see the iPhone 4 tear down and can see the tools.
这个答案有帮助吗?
得分 1
添加一条评论
Since you asked this question, iFixit added a special standoff bit to their tools catalogue.
iPhone Standoff Screwdriver Bit (Item code: IF145-343-1)
I use a 'STANLEY 63-310 U.S.A.' pocket slotted screwdriver for this task. It is good, though not perfect: its blade is just slightly wider than screw head, so it will collide into nearby components. I need to slide it slightly after every half turn, so it overhangs clear/free area, instead of overhanging populated area and bumping into parts.
这个答案有帮助吗?
得分 1
添加一条评论
Very small slotted (flat) head screwdriver.
这个答案有帮助吗?
得分 0
1条评论:
1.5mm flat head has been my preferred choice
完成的
添加一条评论
添加你的答案
Stephen Jennings 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 52
总计 2,103
