Wifi antenna wire color
I am just wanting to know what color the wifi antena wire is Is it the white one or the black one I am wanting to add an external ariel
Here is an image link that should help you with your question. This is the wifi assembly for the playstation 3. So it should be the black cable. If you have any further questions please come back and we will assist as soon as possible.
这个答案有帮助吗?
Cool thanks for that But I have a new super slim model and wifi antenna is different to that In one vid I seen the guy says the black wire as well But seen another and they say the white one
I spose if I just disconect one put back together and see what stoped bluetooth or wifi then i know what one is what :-)
lol whoops, ok yes, I would say try unplugging the black cable first. It would make more sense to keep the standard with the same cable, and the white one should be the bluetooth antenna. sorry about that!
No thank you for the quick replys I will try black first then as I am with you if they used it in past why would they change :-)
It is the white wire in the super slim 500gb model I have it was written on the motherboard :-)
Nice! That's good intel to know thanks for the update!
Are the antennas clipped on or soldered on?
这个答案有帮助吗?
It's the white wire and it clips on. I use a small 14 db gain antenna for mine. I get 92% signal from 200ft. :)
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 34
总计 4,954
1条评论
Cual es el cable del WiFi de qué color es de las 2 pequeñas placas en el ventilador
由 P.R Alfa Alfa 完成的
