跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
Why "No Service" after replacing LCD screen?
I just replaced the screen of my S4 and it said 'no service' so I took it apart again, think the antenna wasn't connected properly so clicked that in and it was fine. However, now the signal has gone again and it says 'no service'.
Any ideas?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
So the signal was working again after you connected it?
这个答案有帮助吗?
得分 0
2条评论:
When I first reconnected it it wasn't working, so I took it apart again and made sure the antenna was connected right, and when I turned it back on the signal was working for around half an hour before stopping again?
完成的
Take apart again and disconnect antenna again and reconnect if it still doesn't work I would buy a new antenna
完成的
添加一条评论
I had no service also. Galaxy s4 active. I took it back apart and found that the blue antenna jumped the track it runs in and I threaded a screw right through the middle of it. I couldn't do it again if I tried. lol. I'd check your antenna connection before doing anything.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charlie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,537
