跳转到主内容
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
62 个问题 查看全部
CD stuck inside the unit. Help?
I have a mac mini as listed A1103 it belongs to my girl theres a cd inside the unit and it doesnt come out and seems to be causing some kind of error because the unit doesnt post. Is the cd inside causing the problem, in any case this is the issue how do i take the cd out?
Or do i have to replace the optical drive?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Restart holding down the mouse button and it should eject.
Also try:
Open the Terminal in the /Applications/Utilities/ folder and run:
drutil eject
这个答案有帮助吗?
得分 2
2条评论:
thanx let me try that now! im not very talented with macs. I work for HP maybe thats the answer but thanks!! another quick question..that is causing the problem of being unable to start up?
完成的
Let's get the CD out and see what it looks like. The unit may boot fine. If not let us know and we'll diagnose further.
完成的
添加一条评论
If your CD is stuck and none of the other methods work, you might eventually try pulling out your optical drive and doing this: Optical Drive Disc Removal Technique
这个答案有帮助吗?
得分 1
添加一条评论
You could also try the
double sticky tape trick,
There's many reasons to fail POST however AFAIK a stuck CD is not one of them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ramon Aviles 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 3,415
