跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
iPhone 3G won't turn on
Hey, guys. I have a problem here.
I have had an iPhone 3g for a while now, and the other day, my little brother threw it on the ground. The screen still works, because when it's plugged in I can get the openiBoot screen, but when I load iOS, it turns off as if the battery died (weird imprint of openiBoot screen). But, it loads android without a problem. The phone does not turn on unless it's plugged in, so I thought maybe it was the battery. I ordered a new one from here, and it didn't solve anything. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Have you tried checking to see if you can't boost power to your USB ports?
1 Open the Device Manager by clicking "Start," "Control Panel," "Hardware and Sound" and "Device Manager."
2 Expand the "Universal Serial Bus controllers" tree by clicking on the arrow next to that heading. Here, you will see all USB controllers and USB root hubs (USB ports) on your computer.
3 Right-click on the "USB Root Hub" you want to change, and then click on "Properties" to open the USB port's Properties dialog box. Under the Power Management tab, you will see the option for restricting power to the USB port to save battery power. Choose your desired settings using the checkboxes and then click on "OK" to save these settings.
4 Repeat Step 3 for all USB Root Hub devices to customize the power output to your computer's USB ports.
You can always try later down the road a device like this that plugs into your laptop and not only adds more usb ports, but also gives you power from a wall outlet as well boosting usb port powers and data transfers. Something to consider for the future. http://www.amazon.co.uk/Satechi-Power-Ad...
~Gadget~
这个答案有帮助吗?
得分 1
3条评论:
ERGH! It's supplying more power than it was before but it's still not enough. Is there anything maybe in the bios that I could change? Or another setting in control panel?
SO CLOSE! I feel like we're on to something.
完成的
Check your BIOS to see if you can find an option named "USB 2.0 HS Reference Voltage". If that option is available, change the associated value from "Low" or "Medium" to "High" or "Maximum". That's really the only other option I can think of without having to get an external power source usb port hub that you can plug into your computer and the wall.
完成的
I do not see any setting, even remotely close to that.
完成的
添加一条评论
Start by a soft reset, then a hard reset, then a factory restore with fresh iOS installed.
It is possible to install the battery incorrectly...
这个答案有帮助吗?
得分 0
4条评论:
How do you do these resets?
完成的
I cannot do a reset because I forgot to mention that my computer doesn't supply enough power through USB for it to stay on. Only through wall outlet.
完成的
Try to put it in DFU. If you cannot get enough power for it to charge all of the way, then your only option is to redo everything you did. BTW, I recall a time where I had a 3GS, I replaced the battery and it didn't do anything. I lost interest and threw it in my drawer. Later, I replaced the battery and it happened to work perfectly...
完成的
Okay. So, I put it in DFU mode and let it charge for a good 45 minutes. I unplugged it and tried to turn it on (First I pressed Home+Lock for 15 seconds, then sttempted to turn it on normally) and no avail. But, I put it in DFU mode while on the charger a second time, and plugged it into my computer, and IT'S RECOGNIZED! That's a start, right?
完成的
添加一条评论
You can send your iPhone 3G to phone shop for rooting it. It may be the software problem.
If the problem still remains after rooting, then unluckily the CPU of your phone was broken due to the drop.
这个答案有帮助吗?
得分 0
1条评论:
I would send it in but, I live about 4 miles past where Jesus lost his sandals ( REALLY far out of town) and I'm super duper broke ATM.
完成的
添加一条评论
添加你的答案
Koston Morin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,075
